What is this? (video)
Old 08-20-2013, 10:12 PM
FamousRapper's Avatar
Question What is this? (video)
I cant figure out what this is... The oil cooler was just replaced by someone with a bad rep as u can tell by the hoses. There a hole in the block almost as if a freeze plug or water jacket belongs in it. When i start up the whip it smokes a lot. It smells like oil burning but im no 100 percent sure.
2002 volvo s80 2.9l non turbo - YouTube
you see the hole around 0:14, its right above the oil cool and under exhaust manifold. thanks.
Old 08-21-2013, 05:18 AM
ES6T's Avatar
Yep, the plug popped out. That's for oil return from the turbo on a turbo engine.
After replacement, make sure the PCV isn't clogged.
Old 08-21-2013, 11:06 AM
Well let me ask this, when the engine is running and I look at this hole shouldn't I be able to see coolant or oil leaking excessively from that hole? All I see is smoke and it might be from the oil cooler hose leaking on to the hot pipes and exhaust.
Old 08-21-2013, 11:54 AM
ES6T's Avatar
No coolant. They usually leak oil though. More so when revving.
Old 08-21-2013, 12:39 PM
Makes sense since my the car looses 1 quart every oil change (3k). The car belongs to one of my babies mammas so ill check the pcv when I see her tonight. Also any clue what the part # is? I am sure I can search the forum to find a proper installation guide
Old 08-21-2013, 01:07 PM
ES6T's Avatar
Can't check the PCV with that plug missing. I don't have the number but its only a few bucks at the dealer.
Old 08-21-2013, 02:30 PM
any idea has to what they would call that plug? thanks for the help es6t much appreciated.
Old 08-21-2013, 04:46 PM
ES6T's Avatar
The parts diagram just calls it a plug, but if you explain that it goes in the block where the turbo drain tube would go, they should know what you're talking about.
Old 08-24-2013, 08:07 AM
yea i got the plug yesterday from, 6 bucks. Ill probably put it in after work today and check the PCV.
Old 08-25-2013, 01:21 PM
that oil plug is a pain to get in, any tips? i hope i dont have to remove the exhaust manifold. I tried tapping it in with extensions and sockets but the is not room to get a good swing on it.
Old 08-26-2013, 02:01 PM
ES6T's Avatar
Yeah they are a pain in the ***. I've always used a socket and extension, you may need to remove the heat shield.
flamejet
01-06-2008 10:18 AM
S70 Owner
03-23-2006 12:46 AM
white2abbit
03-04-2006 06:02 PM
knight rider
08-26-2005 10:00 PM
hoppr
12-04-2003 10:26 PM
Quick Reply: What is this? (video)
