2006 Volvo xc70 broken hose
Old 03-12-2017, 10:10 PM
thatseasy's Avatar
Default 2006 Volvo xc70 broken hose
Please see attached image, I just noticed the host on the left of the Engine oil cap was broken. The car drives ok except smells oil. What is this host for, and is the car dangerous to drive with it broken? Thanks a lot in advance!
Old 03-13-2017, 05:14 AM
ES6T's Avatar
That's the PCV breather hose and no, it isn't dangerous.
Old 03-13-2017, 07:45 PM
thatseasy's Avatar
Thank you ES6T! What is the skill level to replace the host :-) ?
Old 03-13-2017, 08:14 PM
ES6T's Avatar
I can do them in about 5 minutes. But I'm a professional and have done hundreds.
Shouldn't take more than an hour for an average Joe.
Old 03-21-2017, 11:56 PM
Fataqui's Avatar
I would fix it as soon as possible, because if you don't oil will leak into your upper head area getting your coils and plug area all oily, and if enough leaks up there it will most likely leak down into your timing belt area and could throw a timing belt if enough oil runs down into the timing belt crank gear area. It's not hard to replace it, just remove the plastic cover covering your ignition coils, un-clamp it on that upper end, then loosen the inter-cooler pipe under the intake-manifold that is connected to the throttle body to give you room to pull the other end of that hose off the oil trap.
Narva Chad
12-09-2016 01:19 PM
bubrockit
08-06-2012 12:14 AM
tucker98
11-11-2009 04:16 PM
Volvo850GLTOwner
09-24-2007 03:44 PM
tupapison
07-01-2006 07:03 PM
Quick Reply: 2006 Volvo xc70 broken hose
