Sponsored by:
Sponsored by:
XC90 Brakes-how difficult to change?
Old 03-05-2006, 01:35 AM
m1964's Avatar
Default XC90 Brakes-how difficult to change?
I have been changing brakes on my '95 850, and wonder if set-up is any different on XC90. Also, what tools needed to replace front brakes?
Thanks
'05 V8
Old 03-05-2006, 03:11 AM
Default RE: XC90 Brakes-how difficult to change?
The tools are the Same but it is a little different.
It is kind of hard to explain. The pain is with the springs on the pads. Once you try and figure it out you will see what I mean.
Old 03-11-2006, 05:34 AM
Use a screw driver to pop out the spring. Pry it out from the middle and make sure it doesn't it you in the face or something. In my opnion the easiest front brakes other than the new R's.
Old 03-14-2006, 02:57 AM
m1964's Avatar
Thanks to all - I will be rotating tires this/ next weekend, will look closely at the brakes.
Tech-I did not get to Cruise control switch yet-was working 6 days a week.
Old 06-10-2006, 06:53 PM
Just stick a flat blade screw driver in between the spring and caliper pop it off then compress the pads with the same screw driver then the 2 7mm allens on the back of the caliper. Pop the old pads out. Before you put the new pads in use some of the volvo pink brake grease for the back of the pads. Install the new pads bolt on the caliper. Then reinstall the clip slide one side under with the center started old the center with one hand and pull the other side down get if a tap with the end of the screw driver to make sure it is seated bolt up the brake and you are done. Clean the center of the hub when the wheel is off to make sure it seats when you reinstall it .
Old 06-11-2006, 07:11 PM
m1964's Avatar
Thanks- I did the job a while ago, but I am sure your instructons will help someone else too.
What do you mean saying
- I usually pull the old pads out, then compress cylinder back into the caliper.
Old 06-11-2006, 10:12 PM
Alot of the time it is easy to compress most of the way before you remove the caliper by using a screw driver.
Old 06-13-2006, 12:19 AM
m1964's Avatar
Could I damage the rotor by doing that?
Old 06-13-2006, 07:22 PM
Depends on how much pressure and where you press against.
If you do it easy the worse that will happen is a little scratch that will come out the first time you hit the brakes to slow down.
TLC_Lover
07-01-2013 12:19 PM
scottc_00
01-26-2013 10:25 PM
Yachtman
08-08-2006 12:32 AM
spyder
03-18-2006 12:36 AM
cgerdeman
09-10-2005 01:54 PM
Quick Reply: XC90 Brakes-how difficult to change?
