Sponsored by:
Sponsored by:
XC90 - No High Beams.
Old 07-21-2014, 11:23 AM
branse's Avatar
Unhappy XC90 - No High Beams.
I have a 2004 Volvo XC 90 AWD, with no high beams. There’s one HID bulb, and one Halogen bulb per side. I know the main HID bulb serves as both low and high beam, and the reflector/deflector thing is supposed to move up and down to project the light low or high when required. (correct me if I’m wrong please)
Here are the symptoms.
1. The Halogens come on as DRL’s in the daytime, if the dashboard switch is set to OFF. (Good)
2. The low beam works fine if switched on manually anytime, and the DRL’s go off. (Good)
3. The low beams work if it’s dark, and switch is set to auto, and DRL’s go off. (Good)
4. When the headlight is off, when flashing high beams to pass, the low beams come on. The blue indicator on the dash lights up, but only the low beams flash.(Bad)
5. When the lights are ON, low beam is fine, but when switched to high, the blue light indicates in the dash, but the light remains on low beam. (Bad)
6. When flashing the lights, the relay under the steering wheel goes “tick”, indicating it’s working. (Replaced this for good measure).
7. The high beam fuses in the engine compartment (fuse 20,21 – 15amp) get power when high beams are switched on, and lose power when switched off. (Good)
I’m wondering I the dealer at some point coded this out??
Any help is appreciated.
Thanks
Branse
Old 07-23-2014, 02:34 PM
IWantATurbo's Avatar
dumb ? but you know the bulbs are good? there is also extra wires that hook up on the hids maybe they got un hooked when the housings where out of the car at some point?
i do know on mine they only work when i move my switch to on, mine will not work on auto.
Old 07-23-2014, 05:58 PM
branse's Avatar
Bulbs are good, they work on low beam. The lights are always left in the ON position. This is to do with the flap thing that is supposed move up and down for high and low beams.
Old 08-15-2014, 09:04 AM
chaspan's Avatar
Don't feel bad. I have no headlights at all for right now. No highs or DRLs or low beam. They all stopped working yesterday, all fuses check out and bulbs are all good. Open for ideas.
98isb360
10-13-2021 08:47 AM
bkhan145
03-16-2019 02:22 PM
Austinfamvt
09-04-2015 05:31 PM
SilentBob
10-01-2005 05:42 PM
Volvos since 1964
02-07-2005 10:55 AM
Quick Reply: XC90 - No High Beams.
