1998 V70 XC Service Manual?
Old Mar 16, 2015 | 12:06 PM
RCSnyder's Avatar
Default 1998 V70 XC Service Manual?
Okay, I searched the threads first using a number of possibilities and seemed to come up empty.
Is there a downloadable version out there for the asking?
If not, perhaps someone could point me toward the service procedure for the transmission?
Thanks in advance.
Bob
Old Mar 17, 2015 | 11:12 AM
Most of what I've read says you can drain/fill or flush the transmission fluid, but make sure you use the proper/recommended replacement fluid type. Some people have tried to upgrade or use different specs with negative results. The easy way is to drain and refill which gets about 1/3 to 1/2 the fluid so some people do that a few times. The other way is to disconnect the transmission cooler, put two hoses to two buckets - one for the waste the other to suck in the fresh fluid. There are some youtube vids on the how to...
The AWD bevel gear (angle gear) is different system and uses gear oil (ie GL4 75/90 WT). check out http://www.volvoxc.com/0/resources/h...eplacement.pdf
lilbud
Dec 7, 2010 07:37 PM
tylerddean@yahoo.com
Aug 19, 2010 09:32 PM
sweedster62
Jan 29, 2010 07:20 PM
Sanel30
Jun 21, 2009 12:29 AM
azmatkhan
Jan 4, 2004 11:41 PM
