1999 v70xc transmission problem
My trans suddenly stopped and the forward arrow came on. When it cooled down (not overheated), but normal operating temp it would go another mile then quit. My question is: could it be something other than the trans? In addition when I bought the car 2 years ago the drive shaft had been removed and it performed fine. If I need another trans could I use a FWD trans instead of the AWD trans as I don't need AWD? The FWD trans is less than 1/2 of the AWD version. Any help would be greatly appreciated.
Deke MacPherson
Deke MacPherson
trans replaced with the FWD and now code problems
Replaced thr trans with a 98 FWD and new axle. Works fine except the following codes are coming up alond with the check engine light which won't allow inspection.
P1618-----fault in lead between AW5052 and MOTROME 4.3
P717
turbine/input
shaft speed
sensor ciscuit
no signal
Any info or help with problem would be greatly appreciated
Thanks in Advance !!!!
Deke MacPherson
P717
turbine/input
shaft speed
sensor ciscuit
no signal
Deke MacPherson
