Adding new key to 1997 V70 via OBDII - what hardware and software?
Old Sep 11, 2012 | 06:06 AM
dcam's Avatar
Default Adding new key to 1997 V70 via OBDII - what hardware and software?
Locksmiths around here haven't been able to dupicate the 1997 V70 key due to its.type of transponder, which their equipment identified as ID44.
I have the ignition key pin and the immobilizer pin for the vehicle.
There are many types of hardware links that can be used to link a computer to the car via the OBDII plug, including some that you can buy for just $10.
What hardware and software is used to make the car recognise a new ID44 key? Can that cheap hardware be used, or is something more fancy required?
Or is it possible to tell the immobiliser to turn off such that just the mechanical key can be copied?
Regards,
-- Dave
Old Sep 11, 2012 | 06:18 AM
Hi Dave, please verify the year of the car in question. I don't believe the'97 or '98's for that matter were chipped, at least not in the USA cars. I usually contact a dealer, usually one 2 or 3 states away, prove my ownership, then they send me a pre-cut key that works right out of the package.
Old Sep 11, 2012 | 09:40 PM
dcam's Avatar
The year is 1997 (correct), and I'm from Australia, which is likely the explanation.
The key is definitely chipped. In fact I have a non-chipped key which opens the doors and turns the ignition and starts the starter motor, but it won't successfully start the car.
Do you know if Volvo VIDA software has the capacity to configure the car keys, if you have the ignition key pin and immobiliser pin?
Old Sep 11, 2012 | 10:54 PM
No, I don't know.
Old Sep 14, 2012 | 08:24 PM
welderman22's Avatar
Hi, couls someone tell me why does my v70 vreg alarm goes off for no aparent reason? i turn it off with the fob, and leave it off, it resets its self again moments later, someone said it might be coins in the holder???? never heard that before, any help would be great, I,am new to this forum, cheers Doc
Desecreight
Jan 19, 2014 09:31 PM
ivolution
Aug 1, 2011 06:59 AM
Breals
Jan 29, 2010 02:05 PM
Eple
Aug 30, 2008 06:05 PM
