ETS Light
Old Jan 24, 2022 | 10:30 AM
JD1965's Avatar
Default ETS Light
Surprised search of the forum did not turn up anything on the ETS (electronic throttle system) light.
Mine is going on and off intermittently and sometimes I'll get a surge or a cut back in the throttle while driving.
Is this a component and easy to switch out? Something I can clean?
Any knowledge shared, much appreciated.
John
Old Jan 24, 2022 | 12:08 PM
The 99-2000 svxc70 (and many other volvos/other brands) used the Magnetti Maerelli (sp) throttle module. They are known to fail with less than 100k miles. Several aftermarket companies have made modifications to the existing module during "rebuilding" to eliminate the parts that wear. If you came to me and your module needed to be replaced - I would order a replacement from xemodex pre programmed to your VIN and install it the next day. Plug and play, problem solved.
It has been mentioned that a used unit MIGHT work in a different car, if the moon is in the right phase and such, but I have no experience in trying used throttle modules. Or you can purchase the replacement parts and rebuild your yourself.
https://xemodex.com/us/product/elect...re-programmed/
Old Jan 30, 2022 | 06:02 PM
JD1965's Avatar
Wow. Thanks so much hoonk! As soon as I can get to it, will let you know how it turns out.
Thanks again man!
jloco
Jul 25, 2012 01:09 PM
lotusing
Jun 19, 2012 01:13 PM
RyBred
Dec 28, 2010 11:25 AM
Peti
Aug 10, 2010 08:13 PM
louduva666
Aug 23, 2004 06:38 PM
