Instrument Panel Lights not workinking
Old Oct 18, 2013 | 04:06 PM
vinograd's Avatar
Default Instrument Panel Lights not workinking
People,
This is my first post so if I leave anything out please tell me.
The car is a 1998 V70 station wagon, just purchased. When checking it out, prior to purchase, I neglected to check if the display panel lights work, they do not. I have examined the fuse (#35) and swapped it just to be sure. No joy. I have wiggled the light intensity wheel - no joy. I would be happy to bypass the light intensity adjustment if that would help.
Can anyone suggest what the next step might be?
Thanks,
Dave
Old Oct 19, 2013 | 05:34 PM
vinograd's Avatar
Default Panel Lights Rotary Intensity Switch - 1998 V70
People,
Can this switch be removed from the front of the housing - I want to see if I bypass it whether the panel lights will work.
Thanks,
Dave
Old Oct 19, 2013 | 07:55 PM
Have you checked the ignition switch?
It could also be the head light switch.
Old Oct 20, 2013 | 11:56 AM
vinograd's Avatar
Default Instrument Panel Lights not working
Hi,
Thanks for the response.
There are no apparent problems with the headlight switch - the parking lights and main beams work fine. And no apparent problems with the ignition switch, the car starts without a problem.
Where do you suggest I begin ?
Dave
Old Oct 20, 2013 | 01:40 PM
The head light switch. The dimmer could also be bad.
Old Oct 21, 2013 | 06:40 AM
vinograd's Avatar
Default Dimmer Switch Access
People
How do I get to the back of the dimmer switch to test it. I assume there is a feed wire from the headlight switch and 1 or more wires to feed the instrument panel lights.
Can the switch be pulled out from the front or do I have to take the dash apart? If I have to take the dash apart, is there a video?
Dave
Jim-1995 850
Jun 20, 2024 10:32 AM
tobolate
Oct 12, 2010 11:04 PM
jrcochranusa
Feb 19, 2010 02:30 PM
ctharley
Mar 15, 2007 04:23 PM
