oil consumption
Old Jun 16, 2014 | 04:41 PM
kawish1659's Avatar
Default oil consumption
Hi
I have been a member since while but never use this amazing Volvo forum
I have a 1999 V70 XC 2.4 turbo I am wondering about the oil consumption, if I drive 2000 miles highway my car did not use any oil, but just by going to work 50 miles a day my car is using oil I don't understand why is anyone could help me on that ?
Old Jun 25, 2014 | 03:04 PM
Pejyt's Avatar
I've heard from my mechanic that it is normal. Well not excessively...
Old Jun 27, 2014 | 09:03 PM
kawish1659's Avatar
I use synthetic oil and after driving 3000k or 5000Km I had a quart of oil
Old Jul 23, 2014 | 06:36 AM
New Member is a place to introduce yourself and your car but your cars area is where to ask for help. You are also much more likely to get help when posting questions in your cars specific area. Post moved to correct area.
Old Aug 1, 2014 | 08:55 AM
Oil consumption will vary depending on the use. If your car is using less than 1 quart of oil in 2,000 miles (3200 km), you are doing real good. If the car is not smoking, that is even better.
Are you using the correct weight oil? Owners manual suggest the weight.
A car will use more oil when cold. So, if you are taking short trips, more oil will be consumed or leaked past seals, etc. Doesn't sound like enough usage to worry about, just keep it between min and max.
Old Aug 2, 2014 | 10:15 PM
kawish1659's Avatar
Thank you for the reply, one other thing that I am confuse about, some morning when I crank up the car there is some smoke coming out from the exhaust pipe and I can tell it is from oil, it seems like the valve seal are leaking a bit but not every morning, usually when the valve seal are leaking it should smoke every morning but not my car it is only some morning and that is really confusing
Old Aug 3, 2014 | 05:04 PM
All cars should smoke condensation when started in the morning.
You never said what weight oil you are using?
Old Aug 3, 2014 | 05:40 PM
oragex's Avatar
The PCV system will get clogged when the car is used for short distances, with or without synthetic oil and no matter the oil change interval.
Your PCV might be already clogged. It's one of the causes of oil consumption.
Old Aug 4, 2014 | 07:43 AM
kawish1659's Avatar
Default Oil
I use Mobil syntec 10W30
But in the morning it is not condensation some day it is smoke from oil
Sofar.
Dec 1, 2008 10:40 AM
mparker
Aug 31, 2008 08:29 AM
97gator
Feb 16, 2008 09:51 AM
Buck
Jun 11, 2006 12:36 PM
gent
Aug 27, 2005 03:27 PM
