serpentine belt problems
Old Feb 23, 2012 | 04:34 PM
whelderwheels613's Avatar
Default serpentine belt problems
So, about ten minutes ago, I started up my '99 V70 base model, and it made some weird sound in the engine and failed to start, so I tried it again and it started right up. However, the first difference I noticed was the battery icon on the dash, then I noticed that I had no power steering, so I instinctively thought it was the serpentine belt. Popped the hood and saw the belt had managed to jump off of the power steering pump. I also noticed below it something had broken off and was causing it to go loose. Here is an image:
Old Feb 23, 2012 | 09:06 PM
Looks like the belt tensioner broke.
Old Feb 25, 2012 | 04:58 PM
well apparently, the pulley snapped off of the bracket that holds it, the alternator, the ac compressor and the power steering pump, and that the bracket had a crack in it, making it useless. Wouldn't have discovered the crack unless the bold had snapped in half in the bracket.
Old Feb 25, 2012 | 05:53 PM
I wonder if someone cross threaded a screw to begin with. Then maybe that is what cracked the bracket.
Old Feb 26, 2012 | 10:11 AM
It makes me wonder if the bracket had cracked when the pulley snapped off or if it was already like that to begin with.
Old Feb 26, 2012 | 10:13 AM
Agreed.
That bracket is also a pain to replace. All the accessories have to come off to replace it.
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
iscwebe
Feb 9, 2010 12:50 AM
rmmagow
Dec 20, 2008 08:53 PM
rationull
Aug 15, 2007 06:12 PM
toine910
May 14, 2004 08:57 PM
