Wobbling cam gear
Old Feb 16, 2015 | 02:36 PM
whelderwheels613's Avatar
Default Wobbling cam gear
While changing my spark plugs and air filter, I discovered this wonky thing. My exhaust camshaft gear appears to be wobbling because it's bent somehow. Here's a video of it running, and a couple photos of it. Note the crack in the gear near the bolts holding it to the camshaft. What do you think? I've already gone through the whole broken-timting-belt ****, so I would rather not do it again if I can preventatively replace it. What do you think?
Image 1
Image 2
Old Feb 16, 2015 | 02:44 PM
Also, neither of the camshafts have variable valve timing judging on the type of camshaft gear used, but I could be wrong.
Old Feb 16, 2015 | 04:12 PM
ES6T's Avatar
Yikes. Don't drive it, or even run the engine if you can help it. You'll need to remove the gear to inspect. Hopefully you just need a new one.
Old Feb 16, 2015 | 07:05 PM
I've done a timing belt before, would the replacement process be similar? Obviously I couldn't be the cams in place if I have to take one of the gears off and I can't seem to find a good guide on how to do it.
Old Feb 16, 2015 | 10:40 PM
ES6T's Avatar
The most sure way is to use the cam locking tool at the rear of the cams. But it can be done without it since its non-CVVT.
Old Feb 17, 2015 | 02:20 PM
So I could theoretically get away without using a rear cam locking tool? I've watched some videos on using it (needed to replacing front cam seal) and it doesn't seem that difficult to use and is only a matter of removing the air box and cam speed sensor. Also, would I need new bolts that hold the gear onto the shaft or could I reuse the old ones?
Thanks
Old Feb 17, 2015 | 03:04 PM
ES6T's Avatar
You could probably get away without the lock tool if you have a good cordless impact to loosen the bolts quickly without turning the cam.
I would replace the bolts, only because they are cheap and this happened. Better to replace three cheap bolts than bend some valves.
Klunk
Apr 28, 2015 02:42 AM
heyitsomid
Apr 1, 2009 08:45 AM
erndawg
Feb 13, 2009 10:14 PM
Crate45
Jul 7, 2008 10:34 PM
Carbuff
May 19, 2005 04:44 PM
