difference between a 2000 transfer case and a 2001
Old Aug 6, 2014 | 06:00 PM
John D Clark's Avatar
Default difference between a 2000 transfer case and a 2001
I have a 2000 volvo v70xc. The transfer case went out and I have been running on Fwd for a few months now. I found a transfer case on craigslist and purchased it. turns out the dip tard had the year wrong. The used one I just bought is a 2001. At the time I did not know as the old one was in the car still. I only found out once I pulled the bad one out and sat it side by side with my newly acquired used one. I did some research and I have come up with 2 conclusions.
1: the transfer cases or angle drive or bevel gear as some call it can NOT be repaired or rebuilt. Is this true?
2nd: the 2001 one transfer case will NOT work int he 2000. Is this true and if so can i please have a reason. Is it geared different? Will it not fit? clearance issues? what is it that makes it not cross compatible?
Thanks in advance.
Old Aug 6, 2014 | 09:21 PM
ES6T's Avatar
1. The parts are not available separately from Volvo.
2. No, not as far as I know. Off the top of my head, the prop shaft flange is different. I think one is longer. I'm also not even sure it will physically fit. Never tried it though, I only install correct parts. You've already got it out. Try it and see.
davidilges@yahoo.com
Nov 25, 2010 09:38 AM
catinct
North East
May 21, 2009 09:00 AM
cody
Apr 8, 2008 08:34 PM
Reddie345
Jan 7, 2007 06:21 PM
