Engine idle rough
Old Mar 9, 2013 | 06:50 AM
Michael P. Dixon's Avatar
Default Engine idle rough
I have a 2000 XC70 AWE SE. PVC has been changed and cleaned out. 146K
The engine idles very rough it varies up and down between 1000 and 500. Nocodes, can't see or hear any vacuum leaks. Doesn’t stall out just reves up anddown all the time.
Does anyone have any idea?
Mike
Old Mar 9, 2013 | 08:01 AM
Have you scanned for codes? Also, you may want to check closer for vacuum leaks.
If you have a scanner, unplug the MAF and see if the idle stabilizes.
Old Mar 10, 2013 | 02:31 PM
Un plugged the MAS and it got worse. Still no codes.
Thanks,
nkinkade
Feb 28, 2014 08:49 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
XC Islander
Sep 12, 2007 08:41 AM
