2002 V70 - White smoke from exhaust
Old Jan 4, 2014 | 03:07 PM
Wharf1999's Avatar
Default 2002 V70 - White smoke from exhaust
-2002' V70 84k and I have white smoke coming from the tailpipe, specifically at a stop. The smoke will come out of the dipstick if I pull it at idle. Based on what I have read on the forum I think I should do the PCV system. My first thought is it could be the sign of a bad turbo. The car has runs a bit rough at idle stop in gear. In neutral the car doesn't have a rough idle. At speed the car seems to run fine.
Any thoughts?
Old Jan 4, 2014 | 07:45 PM
Old Jan 12, 2014 | 03:27 PM
Wharf1999's Avatar
Update -
The white smoke stopped on it's own. I let the car sits a few days . after reading up on possible causes, I did the glove test on the oil fill cap, and co-incidentally noticed no smoke. The glove showed noticeable vacuum. It's very strange because the problem seemed very serious -I'm talking a lot of smoke - like envelops the car at a stop light.
But I ordered the PVC trap & hoses, and spent a day putting it in. Good thing because the trap was totally plugged and filled with liquid. There was water mixed in, the emulsified creamy light brown mix. The connections to the block were also plugged solid.
The car seams to run fine now.
guss1981
Nov 17, 2011 10:23 PM
chio
Nov 22, 2010 04:07 PM
sdguy
Oct 4, 2010 08:30 PM
dandistefano
Sep 21, 2009 10:15 AM
soccermom
Apr 12, 2008 08:00 AM
