white smoke from exhaust
Old Nov 14, 2011 | 05:30 PM
guss1981's Avatar
Default white smoke from exhaust
I have a 2001 s40. It started white smoking and then it died. I was wondering what I need to look for.
Old Nov 14, 2011 | 06:08 PM
Could you get it started again? How much smoke? Enough to choke a small village or just one room?
Old Nov 15, 2011 | 05:32 AM
guss1981's Avatar
Yes it started back like two times. And it was a lot of smoke. Now it will not start back.
Old Nov 15, 2011 | 09:10 AM
It's possible that your piston is flooded out or something if you got a lot of coolant on top of the piston. My guess would be that you BLEW a head gasket. I assume it still cranks. You can pull the plugs out, crank it and see if coolant squarts out. Time to have it towed to a shop for a good check out.
Old Nov 15, 2011 | 01:47 PM
malaka's Avatar
White smoke almost always means coolant is leaking into the combustion chambers. Head gasket blown, or worse a cracked block. Don't dirve the car even if you get it started until the problem is diagnosed and fixed.
Old Nov 15, 2011 | 05:50 PM
Don't let it sit to long it can lock up the block. Turn it over ever once in a while till you get it fixed.
Old Nov 17, 2011 | 10:23 PM
capwheel's Avatar
Agree that it's probably a bad head gasket. Don't drive it any more or you can ruin the engine. Tow it to a repair shop. Head gasket resealing is not too big a deal.
SwedeInLA
Feb 2, 2012 07:15 AM
chio
Nov 22, 2010 04:07 PM
sdguy
Oct 4, 2010 08:30 PM
dandistefano
Sep 21, 2009 10:15 AM
soccermom
Apr 12, 2008 08:00 AM
