2004 v70 PCV oil trap replacment
Old Jan 31, 2015 | 03:06 PM
  #21
shoeboxOH's Avatar
Originally Posted by oragex
If you decide to drop the pan, drain the oil and filter the night before, so you don't have it leaking all over the place when the pan is out. And check again the pcv box is cleared, maybe it can clog up quickly if the oil pan passage is clogged.
How big of a project is dropping the sump pan? I did some research and it looks like a huge PITA project. Are we talking a few hours, or a weekend? Also, the info I saw used a special jack to hold the engine from the topside. If that's the case, I have no idea where to procure something like that (rent?).
Old Feb 12, 2015 | 08:16 AM
  #22
Spencercat's Avatar
I'm about to drop the oil pan on my 2.4 '05 V70. From what I can tell, it's not a huge job, aside from the usual work. Just a lot of bolts holding it on (30) and the need to use the special Volvo gasket maker material ($$ for a tube you will only use once probably). Did you try the glove test on your oil fill cap? The clogged oil sump tube can cause too much vacuum, which can make the system whistle. Also, there is a diaphragm on the PCV breather box which can break and cause it. Saw that on a youtube video. HTH
Old Mar 8, 2015 | 12:53 PM
  #23
shoeboxOH's Avatar
Spencercat, how did this project go for you?
Forsyth
Nov 6, 2011 03:01 PM
southernoregondefense
Jun 26, 2011 10:57 PM
mikhailarey
Sep 25, 2010 06:21 AM
thefrenchman89
Oct 4, 2009 11:28 PM
gary_s
Jul 19, 2009 07:19 AM
