2008 V70 Oil leak at timing cover
Old Jan 15, 2025 | 08:57 AM
bkinney's Avatar
Default 2008 V70 Oil leak at timing cover
I bought a 2008 V70 with 75k on it. Had a few minor issues but after a month I started seeing oil drops under car. I took it in to mechanic and he said it was the vacuum pump and replaced it. After that the leaks went from dime sized to pancake size. He looked at it again and said it was coming from the timing cover and tried to seal it with heavy duty sealant which did not work. To replace seal it is over $1800 and he said I should go ahead and change timing chain and tensioner since it would be easier to do it while cover off. In the meantime I bought a new PCV unit as I had read that a faulty one can cause oil leaks. Been to cold to put it in but does any one have similar experience or suggestions?
Bill/Indy
Old Jan 16, 2025 | 02:05 PM
which engine do you have?
Old Jan 16, 2025 | 05:43 PM
bkinney's Avatar
3.2...thanks!
Srkborders
Jun 18, 2019 07:48 PM
Edie Keck
1998-2000 model year V70
Oct 6, 2018 04:35 PM
savara12
Mar 21, 2018 01:47 PM
benpineapple
Dec 1, 2013 12:02 PM
treeman75
Nov 21, 2010 07:26 AM
