abs light
Old Mar 12, 2013 | 04:18 PM
sandragsds's Avatar
Default abs light
changed the hubs on the back wheels (not volvo parts) and now the abs light is on. Got the abs reset but immediately comes back on again as i drive up the road is it because i have not used genuine volvo parts that the sensors wont pick up the abs. V70 '02 2.4 diesel. Thanks. Also would it fail an Mot on this?
Old Mar 12, 2013 | 08:28 PM
ES6T's Avatar
Yep, most likely a low quality aftermarket part that has either no tone ring in the hub or the incorrect spacing.
Old Mar 15, 2013 | 01:46 PM
sandragsds's Avatar
Thank u for your reply does that mean i have to change the hubs again and would i be forced to use genuine volvo parts
Old Mar 16, 2013 | 09:52 PM
ssicarman's Avatar
When the ABS codes were cleared what were they? Assumption would be for one of the rear wheels. Did you double check the rear ABS system components for damage?
Old Mar 17, 2013 | 09:19 AM
ES6T's Avatar
Unless the axle bolts were not reinstalled or both sensors were damaged/not secured, then yes, you'll need to replace the hubs again. You can try another aftermarket one, but sometimes you get what you pay for.
I would find out what the codes are though. Maybe its only one side and there was a manufacturing defect with one hub.
Old Mar 17, 2013 | 02:34 PM
sandragsds's Avatar
kwik fit cleared the codes and said it was on both wheels i dont know anymore details than that.We have double checked the sensors and cleaned them
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
