Airbag light
Airbag light
I have a 2004 V70 Platinum-
I didn't unhook the battery when I changed a fuse-
and when I turned the car on the Airbag light came on-
As a caveat - I just had the airbag replaced under a recall -
II was told by the Volvo dealer they had to teat it to see what is wrong- $$
Can anyone give me a hint as what to do other than taking it to the dealer-
see if you can rent/borrow a code reader from Autozone etc that supports reading/resetting SRS codes. EIther that or tell the dealer or a volvo friendly indy what you did and ask them to clear the code. If there truly is a problem with the airbag, the code will simply reappear. I've done this on occasion and most won't push back.
