Blinker out warning, but all blinkers work! Going nuts!
Right blinker works fine.
Whenever I put the left blinker on, it blinks in hyper-fast mode and I get the "turn signal failure" message on the dash.
The thing is ... all the blinkers on the left side light up fine! WTH!!!
I'm stumped - does this mean I should be looking for a new relay?
What am I looking for? It seems the problem would be hard to diagnose since the bulb lights up so there is a good connection being made.
The rear bulb only has one filament. So of it is lighting up, it is fine.
The front bulbs have two filaments, as they act as side markers when the turn signal is not activated.
The socket is a common failure, so when this happens I usually sell the bulb and socket to prevent future problems. You can swap the bulb and/or socket from the other side to test. The socket is only about $12 and the bulb is only about $3. You can probably get the bulb cheaper at a parts store though.
mdrookiam
Apr 19, 2010 08:35 PM
WalterXI
Apr 6, 2010 10:55 PM
