95 850 all lights work but headlights and blinkers, fuse under hood good HELP newbie
Old Apr 10, 2010 | 08:21 PM
mdrookiam's Avatar
Exclamation 95 850 all lights work but headlights and blinkers, fuse under hood good HELP newbie
Brake lights ck, emergency flashers ck, running lights ck, high beams ck. All but blinkers and headlights work. I ck'd fuse under hood and they are good. I am a first time Volvo owner. Any help please.
Old Apr 10, 2010 | 09:48 PM
You might have 2 issues. The headlight switch might be one of them. The other might be a bad hazard switch.
Old Apr 11, 2010 | 07:21 PM
tobolate's Avatar
Tech is far superior in diagnosing these things than I, but when my 850 did what your talking about, I pulled the key back about a centimeter after starting the car, it seems the spring in my ignition switch isn't as strong as it should be, and doesn't pull the key back far enough to be in the III position, queuing the headlights and blinkers to work (also my instrument panel lights wont come on without pulling the key back).
Old Apr 13, 2010 | 09:40 AM
mdrookiam's Avatar
Thank you
mdrookiam's Avatar
I moved the key back. It was the spring and the lights, blinkers are on.
Old Apr 13, 2010 | 09:43 PM
That is usually the electrical part of the ignition switch being bad.
That also usually keeps the SRS and ABS lights on on the dash.
Old Apr 14, 2010 | 06:57 AM
mdrookiam's Avatar
Default Thank you for your advice, its been really helpful.
Oh my heck that would tell me why my ABS light is on. I was going this morning to get a brakes quote, thinking I needed new ones. I should get a new ignition switch instead.
Old Apr 14, 2010 | 07:57 PM
If you move the key back and the lights work and the ABS light goes off then you know it is the ignition switch.
Old Apr 15, 2010 | 06:59 AM
mdrookiam's Avatar
The ABS light went off. It's the ignition switch. Is it best to go to the Volvo dealer for repair of this?
Old Apr 15, 2010 | 07:43 PM
You should be able to swap it out your self.
There is 4 screws holding the covers around the steering wheel. 2 torxes 25 and 2 torxes 15 screws. After the covers are off you should see the electrical part of the switch on the back side of the lock assembly. There should be 2 screws holding it in after you remove the plug. Then you can install the new one.
Old Apr 19, 2010 | 11:32 AM
mdrookiam's Avatar
You have been very helpful, thank you.
Now I only have to replace missing fuel door. I have been to local salvage yards but nothing found. My Volvo is the cranberry color. Ebay is null. Any idea where to find the part cheep?
Old Apr 19, 2010 | 07:53 PM
Also keep an eye on the forum for someone parting a car.
Old Apr 19, 2010 | 08:21 PM
mdrookiam's Avatar
Thank you so much!
Old Apr 19, 2010 | 08:35 PM
If it was like 2 years ago I would have had one.
Your welcome.
Platinum52
2001-2013 model year V70
12
Feb 25, 2013 01:37 PM
VTBricked
Apr 21, 2012 09:42 AM
mountainluv
Jan 23, 2011 09:21 PM
Leemaria36
Jan 13, 2011 01:08 AM
ThunderVolvo
Nov 10, 2008 10:21 AM
