ABS OK; Blinkers, Wipers, Brights Do Not Work
Old Nov 18, 2007 | 03:31 PM
victim's Avatar
Default ABS OK; Blinkers, Wipers, Brights Do Not Work
Had my ABS box rebuilt a year and a half ago. Recently the turn signals and bright lights quit working, wipers work only in slow mode. I believe that was also a fact when the ABS box went out. What's different this time is the ABS light is not on nor the STC service message. I remember at one time hearing there is another control box that controls these and are routed through the ABS box. Is thispartial ABS box failure again or should I look for something else?
Thanks in advance.
Old Nov 18, 2007 | 03:37 PM
Default RE: ABS OK; Blinkers, Wipers, Brights Do Not Work
Your steering wheel module is bad.
Old Nov 18, 2007 | 03:44 PM
tripleb's Avatar
Try pulling the fuse for the SWM (steering wheel module"in the fuse box by the LF door. Re-install and if everything is working normally, then the SWM went to "sleep". Removing power to it resets the unit.
There is a SW update to prevent this in the future.
B
Old Nov 18, 2007 | 10:31 PM
master_pre's Avatar
ORIGINAL: tripleb
B
I too had this problem and the software update resolved the issue. Go to the dealership and get an update done, it should be inexpensive.
Old Nov 19, 2007 | 09:13 PM
mncx's Avatar
90% of the time won't fix it with software.. u have to understand in my opinion software upgrade is used to either hide or to slow down the issue of a complaint. I tried upgrade and let car go.. 90% of the time customer comes back and ending up replacing modules. hope this help
Old Nov 20, 2007 | 07:10 PM
victim's Avatar
Tried several things to reset the system. But what finallyworked was cleaning the battery terminals. There was no message about low voltage. I assume there is an excess power saver that shuts these items down to conserve battery during a low voltage situation. Thanks for all your help.
eplanajr
Aug 20, 2013 11:02 PM
Platinum52
2001-2013 model year V70
12
Feb 25, 2013 01:37 PM
cwebb713
Jan 23, 2011 03:48 AM
zmasterflex
Sep 9, 2009 08:10 PM
