j-roz
Old 11-06-2018, 04:04 AM
jroz's Avatar
Default j-roz
Hello, 2002 V70 XC70 2.4T gearmatic, how/where to fit radiator fan override switch? reason - towing biggish caravan and fan manual control will be of great assistance on long inclines (hot climate in South Africa), if manually can switch fan on earlier rather then wait for ecu commanding on/off sequence. Currently fan goes on too late and experiencing overheating, same sometimes happening in slow moving traffic. please assist.
kind regards
Jan
Old 11-14-2018, 05:37 AM
pierremcalpine's Avatar
I had a similar thing happen in my 03 V40 which may or may not be related. It was fine at high speeds but the minute I got stuck in traffic it would begin to over heat. The over heat condition could be somewhat managed by turning the cabin heat on high and having the passengers suffer instead of the car. Did some research and found out that it was the fan resistor assembly that was defective. It would allow the fan to turn on at low speed but was preventing it from kicking into high gear when the heat kept climbing. The unit could be purchased separately but the dealership needed some help finding the part in their DB.
In in the case of the V40 the fan resistor is located right on the back of the fan cowling. Looks like a long shotgun shell with wires coming out of it. Not sure if that helps you.
ingydrummer
02-28-2020 03:33 PM
Talegater
12-18-2018 12:57 AM
Jaderlof
1998-2000 model year V70
11-17-2016 01:09 PM
that4wdwagon
12-08-2014 05:23 PM
aprotec58
09-07-2011 01:07 PM
Quick Reply: j-roz
