Change instrument cluster
Old Apr 20, 2016 | 12:13 PM
Thomas larsen's Avatar
Default Change instrument cluster
If i am gonna change the instrument cluster in my 2002 volvo v70 2.4 140hp, how about the km from the old cluster to the used on??? does the km stay in some kind off ecu,
examble
mine shows 262000 km
the used one 136000 km..
witch number will be shown when i put the used one in my car ????
Old Apr 22, 2016 | 03:16 AM
noone?????
Old May 7, 2016 | 03:36 PM
come on, noone know anything inhere?? 108 viws no answer
Old May 8, 2016 | 08:07 AM
pierremcalpine's Avatar
It is suppose to take your original mileage and transpose but I'm not sure if a software download is required to make this happen.
Old May 8, 2016 | 11:39 AM
Ok, hope someone else have tried to change the cluster
Old May 8, 2016 | 11:49 AM
ES6T's Avatar
Just swapping it will do nothing. They are programmed to the car.
You can have the dealer try a DIM reload.
Old May 8, 2016 | 12:19 PM
It is because i have some problem with mine..
the seatbelt light, only light sometimes
one odometer sometimes Resetting itself..
So i can buy another working cheper to fix my own.. so i can take another cluster and put in mine with no problems or???
Old May 15, 2016 | 05:39 AM
Old May 18, 2016 | 01:04 PM
metalbender's Avatar
Your best options are to have the DIM repaired, either by the sponsor in the sidebar, or by Xemodex. The dash bezel and 4 Torx screws hold it in, just one electrical connection plug.
A rebuilt one should be plug-and-play, a used one would likely have to be 'married' to the car. Plus, you're likely to inherit all the used one's shortcomings (and potential failure).
I took mine out, rush shipped it to Xemodex, and had back in the car within 48 hours. Great service, great tech support.
Old May 19, 2016 | 04:46 PM
packetfire's Avatar
For the record, the DIM is not the only place where the mileage is stored, so if you swap DIMs, you get the higher of the two mileages, which is only fair, as otherwise shady used car dealers could swap in DIMs and shave miles off used cars.
Old May 21, 2016 | 04:19 AM
doublebug's Avatar
Right only for P3 cars.
cn90
Apr 24, 2013 01:18 AM
volvo5volvo
May 29, 2012 05:46 AM
PavelG
Mar 18, 2012 01:11 PM
cool_kyle_3000
Mar 5, 2006 11:29 PM
oalsa
Nov 16, 2005 11:12 PM
