Climate control panel LED lights always on
Old Sep 8, 2011 | 07:27 PM
centrex11's Avatar
Default Climate control panel LED lights always on
I have 2005 V70 2.4. The LED lights on the climate control module (CCM) are always on. I checked the fuse and it is ok. I unplugged/plugged the battery - it did not solve the problem. The system (fan, AC, front and back defrost, fan etc...) works fine. The problem is that the LED lights are always on.
After I turn off the engine and remove the key from the ignition and after a delay of approximately 30 seconds the LED lights are turned off. I start the car and all CCM LED lights come back on for as long as the engine is running.
Tracing back my steps, the night before the problem started, I plugged an air pump in the front 12V connection (on the CCM panel) to blow the tires on the car. The 12v connection is working fine. I also removed the fuse for the 12V (thinking there might be a short between the 12v and the CCM panel) but that did not solve the problem.
Any ideas before I take it to the dealer.
Your assistance is truly appreciated.
Wza
Oct 22, 2013 12:26 PM
fixmys80
Sep 9, 2011 12:15 AM
centrex11
Sep 8, 2011 07:34 PM
MrJARichard
Dec 1, 2010 02:43 PM
ultralite2020
Oct 26, 2005 01:06 AM
