2005 S40 Passanger Climate control always HOT
Old Aug 27, 2013 | 10:35 AM
Wza's Avatar
Wza
Default 2005 S40 Passanger Climate control always HOT
So my 2005 S40 with dual climate control started acting up this morning. Whatever the temperature the passage side is set to, it blows HOT HOT air. The driver side works normally, heat is able to be regulated and AC works. Any ideas on what to check? Thanks!
Old Oct 22, 2013 | 12:26 PM
mikebr99's Avatar
Make sure the temp dial is set to change temp for both sides... while everything is on, dial it slowly up to the highest temp and make sure the heat comes out both sides. And then slowly dial it back to a normal temp... both side should follow suit. Mine needs calibrating like this everyonce in a while... though it's usually the driver's side that acts up and blows hot air.
Tks
Mikebr99
centrex11
Sep 8, 2011 07:34 PM
centrex11
2001-2013 model year V70
Sep 8, 2011 07:27 PM
MrJARichard
Dec 1, 2010 02:43 PM
beardo265
Sep 27, 2007 09:24 AM
