Coolant leak—immediate draining
Old Oct 20, 2021 | 04:54 PM
EarlTheVolvo's Avatar
Default Coolant leak—immediate draining
I have a 2001 V70 and just had the starter replaced. We only had it home a day when I discovered the coolant leaks. I can fill it up and it's empty in a few hours just sitting in the driveway. There's dripping in the front on both passenger and driver side—the color is a watery brown. It also looks like there might be some kind of leak in the engine control module box. See pictures. I don't think its the gasket. I filled it and drove 10 minutes, the coolant drained, didn't rise.
Any ideas? Is it worth dumping more money into this car? I like it, but I keep dumping money into repairs.
Old Oct 20, 2021 | 07:45 PM
It's a coolant leak on a 20 year old Volvo - Yep, it's going to cost a bunch to keep that 20 year old Volvo running. It's a personal decision on how much to spend - but don't drive it if it leaks coolant rapidly - you will end up with a damaged head gasket that will cost thousands to fix. On top of what causing the coolant leak now!
The leak is not in the "engine control module box". I'd bet the plastic upper radiator hose neck is broken and it is spraying everywhere. A simple pressure test will show where it is coming from. After radiator replacement, expect every other plastic thing or hose to leak in the cooling system - It's 20 years old. Been there many times both personally and with many customers.
Jones503
Aug 22, 2020 08:38 PM
Ice_Raven
2001-2013 model year V70
Jul 28, 2019 06:44 PM
mhphoto
Jul 24, 2012 07:46 PM
A MAL3 NURSE
Mar 15, 2011 08:41 PM
lcjm225
Dec 25, 2008 10:56 PM
