Cooling problems
Old Oct 20, 2023 | 01:56 PM
NL Craig's Avatar
Default Cooling problems
Hi people.
Got an issue on my 2.4d 2009
The heater seems to be only giving cool air so I checked normal things and noticed the bottom hose was very cool. So as a matter of coarse, I changed the thermostat and housing as I guess it is still original and noticed the top hose was empty.
After I changed the unit and went for a run, the top hose was still cool. The header tank was also still cold. I also noticed there was no water flow through the bleed hose to the header tank. No movement of water in the header tank whatsoever.
It is almost as if the impeller has fallen off the water pump.
Any ideas?
mcward
Aug 3, 2022 11:14 AM
91-740Turbo
Aug 15, 2013 05:06 PM
Ricardobs84
Jun 22, 2013 09:46 PM
buckthedog
Jul 3, 2010 07:07 PM
VJZ
Apr 3, 2009 08:15 AM
