Door Open warning
Old Jun 4, 2020 | 11:18 PM
Ipso's Avatar
Default Door Open warning
My 2009 V70 has just had the 'Door Open' warning appear on the dash. I thought it maybe the actuator or microswitch in the door lock, but it looks like it is a common issue with the wires from the door to the car breaking or coming apart from the connector in the footwell.
Has anyone found an easy way to get to the wires? Do I need to take the door off?
Old Jul 1, 2020 | 08:43 PM
Ipso's Avatar
No one had the issue of the wiring in the connector between the door and body breaking?
This is a design flaw that must affect more then me?
Old Jul 3, 2020 | 06:33 AM
Georgeandkira's Avatar
It's lonely when nobody answers you. I haven't had the joy of a broken wire yet (but will now due to the jynx).
Maybe for starters you can remove the interior panel and get a good look at the lock to see what color wires come rom it so you can more easily identify the broken wire at the hinge. I doubt the door needs to come off.
Old Jul 3, 2020 | 05:18 PM
Ipso's Avatar
Thanks for your reply. I pulled it apart yesterday to look. But it will be a challenge soldering some pieces of wire on to join them.
This is poor design
Two wires broken at the cable tie below the connector
Close up of broken door lock and window wires
Old Jul 4, 2020 | 02:07 PM
You pictured the breaks in 2 wires very near rubber boots of one kind or another.
Maybe you can pull 2 lengths of wire (one for each of the broken ones) through the boots. Then peel out the broken wires to where you can have at them.
Do your splicing then neaten it up.
You're probably done already. G&K
godfearer960
2001-2013 model year XC70
Aug 31, 2018 08:42 PM
schumicat
Oct 11, 2013 11:00 PM
tdeo
Mar 1, 2011 06:19 PM
omar98
May 22, 2009 09:13 PM
tanjung66
Oct 26, 2007 07:39 PM
