false warning that rear door is open
Old Oct 11, 2013 | 10:23 AM
schumicat's Avatar
Default false warning that rear door is open
I am getting a false warning that the rear passenger door is open. On most cars there is a simple plunger switch that tells the car whether door is open, and it is easy and cheap to replace (i've had to do it several times on my Mercedes). I'm not seeing that on the xc90 rear door. Is it built into the lock or something? thanks
Old Oct 11, 2013 | 11:00 PM
damien360's Avatar
the door lock assembly is the part that tells the module if the door is open or not. if its staying in the open position then its probably bad. its easy to replace since you dont have to drill anything out of the rear doors if i remember correctly.
Holedigger
Sep 11, 2021 04:00 PM
John Birmingham
2001-2013 model year V70
Apr 17, 2015 12:13 PM
tdeo
Mar 1, 2011 06:19 PM
MRH512
Feb 22, 2011 10:32 PM
CCHS80
Mar 11, 2010 05:59 PM
