Manual swap, which transmissions work?
Old 01-13-2019, 12:59 AM
Zmarsh's Avatar
Default Manual swap, which transmissions work?
I was looking at doing a manual swap to an '01 t5, it has a manual optional mode but the shift flare from park to drive and 2-3 is getting a bit worse. Was wondering if the M66 from the 2004 R style would work, or if it wouldn't as it's an AWD car and mine is FWD. If not, what others would be cost efficient/would actually work? I know I'd need at least a new set of axles, pedals, shifter, clutch, wiring? and an ECU flash tune - any other definite parts I would need for this project? I have a local garage willing to do the work, but they don't get many volvo's through the door - would like to know what parts I need before sending it in and avoid any surprises. I've done a bunch of engine work on this car like PCV replacement but I have not looked at how transmissions or shifting works at all. Help appreciated. Thanks!
Old 01-13-2019, 12:42 PM
most common way of doing a conversion is to buy a parts car (it can be an NA model) with a manual transmission so you get the pedals, wiring harnesses, clutch, flywheel etc. The only other thing to do is to rewire the PNP circuit (as the AT shifter parts won't exist) - there are some other posts which dicusses this.
Old 01-18-2019, 02:34 AM
Zmarsh's Avatar
I would do that, the only manual volvo's around here are overpriced by their sellers though, and I've only found 1 to be honest. If I was to buy a transmission off the internet, would a 6 speed m66 work? Or do only the 5 m56 speed manuals work?
Zmarsh
01-18-2019 02:44 AM
Phil 850
08-13-2018 11:27 PM
ded137t5r
06-25-2013 01:15 AM
skhalsa86
04-17-2012 02:26 PM
98_S70_T5_Driver
10-28-2009 05:52 PM
Quick Reply: Manual swap, which transmissions work?
