Power Steering Fluid disappearing?
Old Apr 5, 2016 | 05:10 PM
burtongoods's Avatar
Default Power Steering Fluid disappearing?
Hey all, curious if anybody else is having a similar issue to me? I seem to have to top off my power steering reservoir more often than I should. I recently topped it off and it was about 1-2 in. short of topped off. Note: 02' V70, fluid is Pentosin 11s. My brother in law has the same issue on his 04' XC. I've replaced the reservoir which still seems to leak a bit but not a lot. I've never noticed fluid on the ground or dripping anywhere. Anyone else experience this?
Old Apr 11, 2016 | 06:12 PM
checksix's Avatar
Mine as always lost some fluid slowly. Like you I never noticed and oil on the ground, but could see the underside of the car getting dirty. Now within the last couple of week I can see a few drips, but looks more like engine oil than the very pale green 11s. However, I can't find a leak. It coming from up high on the front of the engine closest to the grill (North American car). I'm doing a timing belt change and so can see the cam and crank seals and they are dry. There looked like some oil at the dip stick tube to block interface, so I changed that o-ring out with no results. I had pulled the intake manifold to do an ETM change out, so was able to inspect the area pretty well. It is not leaking at the head gasket.
So all I have left is the Power steering pump. I have that part on order. Anyone with any ideas?
Old Apr 12, 2016 | 02:03 PM
pierremcalpine's Avatar
The hose coming out of the ps pump leading to the reservoir can develop small cracks on the underside especially if a timing belt job was recently done as this hose needs to be loosened and rotated and then gets manhandled a bit. Take a good hard look at this hose especially where it meets the pump to make sure it is totally dry.
Old Apr 12, 2016 | 08:04 PM
checksix's Avatar
You make an excellent point about the suction line from the reservoir. It does take a beating during the timing belt change. In the past I noted oil on this, but never real wet. More like a dirt collector. I've cleaned this several times but it always comes back. I believe a closer inspection is in order, or perhaps just get a new one if I can.
Jerry
Old Apr 13, 2016 | 06:04 AM
Jerry
Take a good close look. That is what mine looked like too. It should remain dry over time.
Old Apr 13, 2016 | 12:39 PM
checksix's Avatar
Last night I ordered one of the after market ones as I've moved mine several times doing timing belt and serpentine belt changes. Less than $25 after shipping. However today I'll take a good look at what I have.
Old Apr 14, 2016 | 01:26 PM
checksix's Avatar
pierremcalpine, last night I removed the Volvo clamp to the suction hose at both ends and replace them with a worm gear clamp. No more leak at the reservoir, but it still leaked at the pump interface. Glad I have a new hose on order.
Old Apr 15, 2016 | 08:07 AM
Glad to hear it. I hope that fixes your leak. Thank you for posting the update.
mudpie
Forum Issues
Nov 15, 2012 03:32 PM
cmayo313
Mar 18, 2011 12:09 PM
s40_owner
Dec 14, 2010 11:17 AM
jareds4
Apr 15, 2010 09:46 AM
Wovolvorine
Aug 7, 2009 11:37 PM
