Roof Rails V70
Hi All,
I have a 2004 V70 and am wanting to add a roof rails to it so that when we travel this summer we can attach a cargo carrier to the roof. Can anyone help this busy mom with the questions below?
Do my existing drip mouldings (?) between door and roof need to be replaced to accommodate roof rails? One body shop says yes, other says not sure. They need painting anyway, but painting them and adding a roof rail set would be a lot less expensive than replacing them if I need them to be a different kind to add roof rails
Feel silly asking, but how would a cargo carrier attach to roof rails? Would I need to have cross bars too?
New to this forum, and any help would be greatly appreciated!
I just bought a used set from a guy on ebay, who sells pretty much only volvo rails and cross bars. The instructions were to lift with a small pry bar that little channel and cut at the predetermined areas to reveal the threaded fittings. The whole job took about an hour and a half. Hope this helps.
These being a stock Volvo accessory called "Roof Mounted Load Bars" for which the roof of any V70 without factory roof rails will accept without modification! As seen here:
These cleats are inconspicuous, but if you look and feel you will find them. There is a pair of cleats at about the B-pillar and another pair further back. If you can't find them, ask the dealer when you get the crossbars to show them to you. The instructions for those bars will explain how to lock the bars onto the cleats.
You do not need any modification to use the Volvo "roof mounted load bars". These bars attach to cleats in the top side channels.
Each load bar "foot" is identified with a sticker by which position each "foot" takes: FL and FR for front left and front right, RL and RR for rear left and rear right. There's a small diagram inside each 'foot' to indicate how to correctly attach to the built-in cleat on the V70 -- so as not to catch the plastic strip that runs the length of the roof. Each 'foot' has itself a pair of rubber pads that are indented to mate up with the cleat.
It would be very hard to install these incorrectly, it takes all of three minutes... and again (I'm not sure why it needed reiterating) no mods are needed for the Volvo Accessory "Roof Mounted Load Bars" Part Number: 31213161:
![](http://desmond.imageshack.us/Himg405/scaled.php?server=405&filename=roofbars.jpg&res=landing)
Hi All,
Good luck
You use the existing trim but it does have to be cut. Once they lift off the trim you will see where to connect the rails, everything is there that is needed. And yes you will also need crossbars. I just did this and bought a set on ebay that worked very well and were inexpensive.
Good luck
Good luck
hovonogila
05-16-2019 02:28 AM
