seat belt locked cant move seat up
Old Nov 15, 2019 | 09:01 AM
Ronald Andrew's Avatar
Default seat belt locked cant move seat up
i have a 2002 Volvo v70 estate folded rear seat down now seat belt has locked up and cant put the seat back to its upright position
Old Nov 18, 2019 | 11:33 AM
moved you to the V70 board - the "forum issues" board is for issues with the forum, not the cars :-)
See if you can press on the top of the folded seat to see if you can ease some of the tension holding the belt against its latching device to give some wiggle room to release.
Old Aug 29, 2020 | 03:53 AM
Derek Waters's Avatar
Default Did you get an answer?
how was this fixed? I have the same problem in my XC90
Old Aug 29, 2020 | 11:27 AM
It can be fixed on some cars by unbolting the end of the seat belt under the seat - the seat can then be raised and sometimes the belt will pull out and retract normally after that. If the seat belt still does not work the seat usually has to move to be removed - to get to the belt inside it.
beleive
Jan 21, 2018 05:08 PM
Bobec
May 21, 2014 11:35 AM
piv15
Sep 28, 2013 05:18 AM
turbo_brick_850
May 18, 2011 10:49 AM
bond007
Mar 23, 2011 11:12 PM
