Shaking and noise on cold start
Old Jun 9, 2021 | 06:46 AM
assgoblin0764's Avatar
Default Shaking and noise on cold start
Hello. My 2001 v70 T5 2.3 blew the intake cam seal a short while ago (PCV was serviced completely 4 months prior), lost 3.3L of oil according to the mechanic shop (most of it leaked out while the car was parked and shut off I think). I had them change the seals and the timing belt etc. since they were covered in oil.
After the job was complete after a long wait, the car shaked violently at idle when the engine was warmed up. I took the car back and they adjusted the timing.
Now the car shakes and makes a slight grinding noise when you start it up after it has sat overnight. The vibration is similiar to the previous one, but only lasts a couple of seconds on cold starts.
I took the car back yet again and they insisted that the camshaft pulley is shot, and they refuse taking any responsibility. The car did not have any problems of this nature before the seals blew/timing belt service.
Any opinions? What should I do?
Thank you in advance.
Old Oct 14, 2021 | 04:26 PM
Mark3's Avatar
Seems you should find an accountable mechanic that specializes in Volvos. If the timing gear is "shot", timing belt change should not be attempted.
Old Oct 15, 2021 | 10:29 AM
+1. Cam seals generally don't just blow out on their own. Common causes are positive PCV pressure or VVT gear issues. Sounds like the gear was bad to begin with and caused the oil leak.
ezjamm
Sep 2, 2020 11:00 PM
Sergt5
May 21, 2020 03:28 PM
cardana24
1998-2000 model year V70
Feb 18, 2017 08:09 AM
vetalbig
Jan 26, 2008 08:58 AM
