Some electrical issues
Old Jan 24, 2015 | 04:08 PM
joeevans's Avatar
Default Some electrical issues
Hi, My drivers side electric window, door, mirror and front fogs don't work anyone suggest anything I should be looking for?? FUSES are fine. Clearly it's just the drivers side I'm having troubles with the exception of fog lights!
Old Jan 24, 2015 | 11:45 PM
ssicarman's Avatar
The fog lights should not be related to the door problem.
If you have checked all of the fuses then try pulling the door panel to check connections and wiring. If all is OK there then check for power (and ground year dependent I think?) to the switch. You may have issues with the wiring into the door from the body.
The fog lights. You have of course checked the bulbs?
Old Jan 25, 2015 | 02:47 AM
joeevans's Avatar
I will check behind the door card today. As for the fogs I will look more closely and however all the fuse' have been checked and are fine!
Lansdowne
Sep 22, 2014 01:02 AM
Beardog
Oct 5, 2010 05:45 PM
FlyBoyd
May 19, 2010 07:06 AM
maglemose
Aug 13, 2009 11:12 PM
