2001 V70 won't start
Old Dec 17, 2014 | 09:50 PM
cmadison666's Avatar
Unhappy 2001 V70 won't start
So I recently ran my 2001 v70 very low on gas, and went to start it a few minutes ago after adding about 2 gallons of gas and it won't stay on for more than about 2 seconds. It's about 100 miles late on an oil change. I've read that it may be a fuel pump relay but i'm having trouble locating it (doesn't seem to exist) any help is appreciated. thank u.
Old Dec 23, 2014 | 11:47 AM
tony1963's Avatar
Fuel is fed into the engine via Internet connection. Drive-by-wire.
Old Dec 24, 2014 | 12:25 PM
well I've really been having issues with the router in it
its about 4 x 6 and yellow and everytime i start the car it goes kaputt! haha!
totally tubular living in 2k14 bro!
Old Jan 10, 2015 | 11:18 PM
dyzio's Avatar
Well, there goes your problem. Never run your car with low gas especially in cold temps. Water will build up in your gas tank which is a no no for the engine. But, Its not like you damaged your engine. Check your owners manual for relay location, or best bet go to
youtube.com Hope this helps. And good luck
Old Jan 28, 2015 | 03:38 PM
joeevans's Avatar
Relay will be situated in the engine bay under plastic tray "FUSES" the fuel pump relay will be located there. Check underside of the plastic cover you removed and it will tell you which one it is! There is also a fuse box inside the car with a "fuel pump fuse" 20 amp (I think) maybe fuse no. 33 check the diagram also and it'll tell you exactly which one to locate. Let me know if this resolves the problem???
VJZ
2001-2013 model year V70
Sep 6, 2013 10:29 AM
Subvol
Dec 11, 2011 06:56 PM
remedave
Oct 14, 2010 10:40 AM
inigo411
Aug 4, 2008 09:03 PM
