SRS light on
Old Feb 19, 2015 | 06:04 PM
immik's Avatar
Default SRS light on
I have an 06 Volvo v70 2.5T. I had an audio shop replace my factory radio. The SRS Light has come on, the backup assist no longer beeps through the radio. Tonight the check engine light came on. Would the SRS light cause the check engine light to come on? Does the car have to be taken to dealership to clear the SRS light? Does backup assist only work with factory radio?
Thank you!
Old Feb 19, 2015 | 06:13 PM
ES6T's Avatar
The SRS won't clear. You need software to remove the radio from the configuration.
Your park assist won't work with the new radio.
Check engine light would be unrelated.
Old Feb 19, 2015 | 11:25 PM
Vida's Avatar
Thank you!
A Dealership will not clear any SRS lights unless the root of the problem is fixed. I'm not surprised what the Audio Shop did, I've seen it all. Installing aftermarket speakers causing the windows to drag, messing the whole MOST system around the amp, etc…
lister99
Dec 28, 2012 10:46 PM
Danigirl
Feb 22, 2012 01:36 PM
guptash
Nov 19, 2011 04:17 PM
Sparky4688
Sep 26, 2009 06:22 AM
strauss8
Apr 23, 2004 07:42 PM
