timing marks
Old Sep 13, 2017 | 03:26 PM
gwelsh's Avatar
Default timing marks
i am rebuilding 04 2.4 non turbo engine. my crankshaft timing marks do not indicate #1 tdc. does this engine not time at tdc #1? thanks in advance.
Old Sep 25, 2017 | 03:32 PM
gwelsh's Avatar
simple question, i wish someone would reply. thanks again
Old Sep 25, 2017 | 10:01 PM
ssicarman's Avatar
There should be a mark on the timing belt sprocket on the crankshaft. On the 2.5 LT it is hard to see I suspect that the 2.4 LT will be just as hard to see.
If you still have the head off of the block then put #1 at TDC and start searching for the marks on the sprocket and the block.
Check youtube or google for timing belt videos for your engine.
Apex
Nov 26, 2015 06:13 PM
Carbuff
Dec 28, 2009 06:24 PM
Soloracer
Aug 26, 2006 04:43 PM
ebrobb
Aug 10, 2006 08:25 PM
