V70 won’t start. Please help!!
Old Jul 23, 2021 | 08:58 PM
Vaswamp's Avatar
Default V70 won’t start. Please help!!
Hey y’all,
I desperately need help and I’m totally out of ideas.
here’s what happened (condensed)
car on ramps, changed oil, had an emergency, crazy rain for an hour while I was gone. Came back next morning. 2001 v70 T5 won’t start!
Here’s what I did.
Removed coils (holes filled with water), sucked all that out and dried off completely
Changed plugs. Will not start..
Confirmed that I have voltage at battery in rear and positive post inside engine bay.
Confirmed fuel pressure at valve on rail.
Pulled every coil and checked for spark (fwiw the light didn’t seem super bright, but I also confirmed a spark on the engine block: again, it seemed somewhat weak but idk).
Checked cranking voltage, seems fine above 10.
Replaced crankshaft position sensor (in desperation)
Poured some HEET in the tank (desperately)
Tried the lawnmower test with cranking and gas pedal.
One side note: I had been chasing an oil leak down the passenger side of the motor, coming from the top: I think this may have just been a worn out oil cap gasket though.
Please help fellas/ladies, I’m at my wits end here and can’t really afford the dealership/towing route. Very rural here.
what am I missing? Had to be something to do with the rain? On an incline too long?
Thanks all!!!!!
Chebucto
Sep 16, 2009 07:46 PM
s70 speeder
Feb 19, 2009 09:12 PM
inigo411
Aug 4, 2008 09:03 PM
inigo411
Jul 29, 2008 04:32 PM
d.stocks
Nov 5, 2007 12:11 AM
