Vibration
Old Mar 4, 2019 | 12:58 PM
propolis's Avatar
Default Vibration
Hi,
Just thought I will share my issue - V70 Diesel Automatic 2010
Driving normally up and down through the gears seems to be OK. Now when I do average speeds at either 30mph, 40mph or 50mph, when I reached those spedds, there is a vivration and when I accelrate slightly it gone. If I drop the speed back to those speeds, it might start again.
I also noticed sometime when I slightly accelerate under tourque between 25 - 35 mph, it could vibrate as well.
They told me it was a faulty gearbox oil cooler and replaced it, but its still going back one more time as the gearbox oil and coolent water got mixed, they have done 3 flushes and want to do one more.
Just some info
Eddie
Old Mar 5, 2019 | 10:19 AM
did the transmission cooler replacement/fluid flush fix the problem?
Old Mar 5, 2019 | 03:56 PM
propolis's Avatar
Default Vibration
No it did not, I think they were clutching at straws :-)
Eddie
Old Mar 7, 2019 | 12:22 PM
does the vibration seem to tie strictly to road speed or when you accellerate at a lower speed? If the latter, I'd check out motor and transmission mounts. If its road speed related, then it could be tires, wheel bearings, axles etc (ie things that rotate).
Hkusp45
Jan 26, 2024 04:37 PM
Kryscent
Dec 7, 2017 02:24 AM
Jomo1
Sep 8, 2012 11:23 AM
gordonproudfoot
Feb 21, 2011 04:48 AM
ryan82
Nov 30, 2010 08:21 AM
