XC70 brake assist service required - ABS
Old Jun 7, 2018 | 02:42 PM
Tony Hill's Avatar
Default XC70 brake assist service required - ABS
I have a 2007 xc70 - 150K...
I routinely get the ABS warning light with an "Brake assist service required" as the associated message. This usually happens during or after a sharp right hand turn?.....
IDEAS????
Old Jun 11, 2018 | 06:59 AM
Georgeandkira's Avatar
I've had no experience with these matters but, posts on this subject are always followed by advice to fully inspect the notched ring and sensor wiring.
I believe a VIDA diagnostic will point to the effected wheel should it come to that.
Old Jun 11, 2018 | 04:19 PM
VIDA will give codes - not sure if they get stored or if you need to scan when this is lit. Usual suspects are the pedal position sensor, the pressure sensor or a wheel speed sensor. Have you had any recent brake work? Sometimes that can alter the brake pedal position and a power bleed may help.
Old Jun 12, 2018 | 10:44 AM
Tony Hill's Avatar
no brake work done.....
DNiefer
2001-2013 model year XC70
Sep 4, 2023 09:36 AM
Brittanie
Apr 3, 2019 08:36 AM
TomT
Dec 19, 2016 04:54 PM
kase6000
Apr 21, 2015 04:36 PM
master16
Oct 31, 2009 07:59 AM
