Brake/ABS warning lights on..
Old Sep 13, 2016 | 12:11 PM
DNiefer's Avatar
Default Brake/ABS warning lights on..
Brake and abs warning lights(cruise and mileage not working) on my 04 xc70. P0571 pd and P0504 pd ECM-9400 u0073. Faulty BCM or pedal sensor or maybe cem??? What I hear is there is two exterior sensor?? one is brake position sensor and brake pedal sensor??
Bought that car over a month ago with abs lights(cruise and mileage not working) on assuming not that complexity and costs but... Replaced rear brake pads and cleaned all wheel sensors. Three times dashes went down after few hours driving and restart after refuel or stopover otherwise motor running ok. Had to take fuse off cem from side passenger and on.. back to normal except cruise and mileage with brake and abs lights on.. all of this I assume it is faulty bcm or pedal sensor or perhaps cem??
Any help would be appreciated very much!
Old Nov 23, 2019 | 07:28 PM
mnvolvo's Avatar
Ever figure this out? Having similar issues on a 2007 XC70.
Old Nov 24, 2019 | 11:40 AM
mnvolvo, did you scan for the ABS fault codes? by "similar issues" how similar? have you had any recent brake/axle/suspension work?
Old Sep 4, 2023 | 09:36 AM
Wessel's Avatar
Have you been able to get rid of your issue ? My 04 s60 has the same codes as the op's car . p0504 and p0571.
Tony Hill
2001-2013 model year V70
Jun 12, 2018 10:44 AM
bgsalbo
Dec 17, 2011 06:32 PM
dragonslair
Apr 17, 2010 02:00 PM
dcb2271
Jan 28, 2010 06:57 PM
trooperone
Jan 3, 2010 09:22 PM
