01 XC does not start
Old May 28, 2012 | 10:03 PM
Covolv's Avatar
Default 01 XC does not start
Hi I'm new to the forum.Have a 01 XC with about 99,000 miles that has been major disappointment.
I can go into that later. For now I'd like to get it running again.
On Saturday it would not start.Engine does ot crank at all. When I turn the key there is a rapid clicking sound and the instrument lights all flash on and off rapidly.
I tested the battery and voltage is fine. I tried jump starting and nothing happenedHave tried starting in both P and N.
Now at the same time this problem happened the message center displayed a message indicating ABS service required.
Any advice on most likely causes is appreciated. I'm wondering if it's two separate problems;maybe ABS module and the started but seems wired that 2 different thing with such different functions would go bad at same time.
thanks
Old Aug 19, 2012 | 10:03 AM
slimflex2's Avatar
could be a number of things causing this.
1. check for fuel pressure. make sure you get fuel at the rail.
2. if it is not cranking it could also be the starter
3.could also be a PNP switch.l dont know if your model has a PNP switch.try to put gear into neutral and try and start. if it does start then your PNP switch needs replacing.
4. if it was cranking but not starting, then your fuel pump relay is at fault.
Old Aug 19, 2012 | 10:17 AM
slimflex2's Avatar
my best guess will be the starter if you get fuel the right fuel pressure.
Old Aug 20, 2012 | 12:46 PM
Covolv's Avatar
Thanks for the replies. I must sheepishly admit it was just the battery. Car is fine now.Thanks again for the advice.
Old Aug 21, 2012 | 06:02 PM
slimflex2's Avatar
no problem brother. l would have asked the condition of your battery because l had this happen to me and it was the battery. but you mentioned you tested it and it was fine.anyways l am glad you got it running again.
Old Aug 22, 2012 | 09:02 AM
Covolv's Avatar
Well I learned that even though the voltage may test fine that does not equate to ample cranking power.
Old Aug 25, 2012 | 08:55 AM
slimflex2's Avatar
l had the same thing happen to me. almost changed the starter, but l decided to change the batteries first and problem was solved.mine had a click when l tried starting it.it was the battery.
Old Aug 27, 2012 | 03:59 PM
Covolv's Avatar
Man I don't feel so bad now. I was proceeding to replace my starter but got to a point where there was a bolt I could not loosen. Am now glad I couldn't!
Do know the sound difference now when it is starter vs something else.
Old Sep 25, 2012 | 04:44 AM
AlanT's Avatar
I've been playing with cars since I was 15 and "CLICKING" has ALWAYS been the battery or dirty posts since 1975 LOL.
Old Sep 26, 2012 | 10:32 PM
XCMomma's Avatar
Default Fuel pump recall
Glad to hear you got it running! I was having some hesitation on accelerating and a hard start with my 02 XC70 AWD. Come to find out there was a recall in 08 on that fuel pump so you may contact Volvo or NHTS to find out if you're eligible for a new pump under the recall. Might as well have it checked even if the battery was the main problem. Got mine replaced yesterday at no charge from the dealership, and it's back to running like a champ!
Old Sep 27, 2012 | 04:26 AM
AlanT's Avatar
mmmm.... I have hesitation and ive asked the dealer a few times about it thinking it was the throttle body! seems more prevalent right now that its cooled off here a bit and it makes sense it could be a fuel pressure issue. will have to text the service mgr about it today.
myanny
Oct 12, 2009 12:21 PM
Liz
Jan 7, 2009 05:04 PM
sato
Oct 4, 2008 08:30 AM
mracr
Feb 14, 2007 12:53 PM
Carlo_Scialla
Jan 5, 2006 10:51 PM
