2007 XC70 ABS light & clicking noise when turning right
Old 08-04-2018, 11:28 AM
Tony Hill's Avatar
Default 2007 XC70 ABS light & clicking noise when turning right
Volvo fans,
- I have an irritating problem.
- Most concerning, at low speeds when making a sharp right I hear a clicking noise - not really loud but certainly a concern.
- I get the ABS warning light all the time - often when turning right (at any speed) - and sometimes just intermittently. The will clear itself sometimes when driving and others when you start back up.
- Thoughts/Ideas????
Old 08-04-2018, 12:30 PM
ABS warning lights can be caused by a wonky wheel speed sensor. The clicking noise is likely the front axle's CV joint. Best to inspect the CV joint boots and if torn and noisy, its time to replace that axle. Also if the boot tears and throws grease on the wheel hub, it can mess up the speed sensor so you may need to clean the hub's inner side and the sensor to fix the ABS error. Note that a shop with a fully featured scanner can read the ABS code and tell you exactly what part (ie which wheel) is setting off the warning.
Old 08-04-2018, 01:07 PM
tony1963's Avatar
I had an 07 V70 not long ago that had the dash lit up like a Christmas tree. The ABS, BRAKE TRACS and message board were going wild. The only thing that wasn't lit up was a heat shield warning on the return capsule.
Anyway, I had a code for the wheel speed sensor on the LH side. I checked the connection, removed the wheel and discovered that the bolt for the drive axle had come loose and the splined portion of the axle had moved inboard enough that the sensor no longer aligned with the tone ring. I tightened the bolt, removed and added some red Locktite and the problem was solved.
On ABS it is almost always the simple things.
Old 08-04-2018, 02:13 PM
Tony Hill's Avatar
I like that "heat shield warning on the return capsule"... :-)
Old 08-04-2018, 02:17 PM
tony1963's Avatar
I bought the car for a song but I wasn't even there. I participated "online" and the car sold for a song. When we got the car, it was as clean as a two year old model and had about 105k miles.
The dash scared everyone off. LOL
Old 08-04-2018, 03:14 PM
Tony Hill's Avatar
I just had a repair on my 2003 V70 DIM using european electronics - TN... Excellent work at a good price......
Old 12-01-2018, 08:11 AM
Tony Hill's Avatar
replaced front axles - GTG....
aPpYe
2001-2013 model year XC70
02-21-2020 08:14 PM
evlwhtguy
05-21-2017 09:40 AM
mrduke
02-13-2017 10:19 AM
Newport_j
08-08-2016 07:25 AM
rpm48
03-17-2006 08:50 PM
Quick Reply: 2007 XC70 ABS light & clicking noise when turning right
