V70 ABS/TRACS Warning Lights
Old Mar 16, 2006 | 05:34 PM
rpm48's Avatar
Default V70 ABS/TRACS Warning Lights
I've got a 1998 V70 that is messaging ABS / TRACS OFF. It is intermittant, but is increasing in frequency. The warning lights go off as irregular as they appear. A few times at less than 3mph, the ABS hydraulic modulator seems to be activating (pulsing noises & pedal feel). It pulses about a second, then stops. There is no effect on braking at speed. I don't know how to diagnose a faulty CU, hydraulic modulator / relays or wheel sensor(s). I sure would appreciate advise on this one.
Old Mar 16, 2006 | 05:55 PM
S70turbo1999's Avatar
Default RE: V70 ABS/TRACS Warning Lights
i had that same thing happen to me during the winter after some e-brake turns in the snow, and that problem continued for a while but then it eventually fixed itself? and went away. how long has this been happening and have u been driving it hard or anything? i also think that the whole "even at 3 mph" thing is because the ABS diagnoses itself after u hit 15 miles per hour or sumthing like that. im not 100% sure but i know at a low speed after being started it will activate or sumthing
Old Mar 17, 2006 | 08:50 PM
Try cleaning the sensors first and if that doesn't fix it the ABS module is bad.
850GLE
Sep 22, 2009 10:28 AM
JimKW
Apr 29, 2009 12:43 PM
ddorshimer
Sep 23, 2008 10:05 AM
paulh
Jan 30, 2008 08:22 PM
Greenrino
Nov 12, 2006 02:26 AM
