2003 xc70 tires question
Old Nov 12, 2020 | 12:53 PM
James Scott's Avatar
Default 2003 xc70 tires question
So I want to put a lower profile winter tire on and honestly dont see why it wouldnt be fine, but that dont make me right.
Want to swap from the standard 215/65 r16 to a 215/55 r16
I know this will drop the clearance about .75in. But will it bugger up the suspention and such by doing so?
Old Dec 3, 2020 | 05:22 PM
pache11's Avatar
The correct term for upgrading aspect ratio/tire size is Plus sizing
Tire Rack lists the 17" wheel as 235/55-17 and 18" as 235/50-18 The diameter is important to match as well as the max width(most P2s 235mm)
A good site to show what options are workable is:
https://www.tyresizecalculator.com/
Old Dec 3, 2020 | 05:27 PM
pache11's Avatar
This will give a comparison of the tires with change in diameter, mph etc.
https://www.willtheyfit.com/
Old Dec 3, 2020 | 07:57 PM
another good resource is wheel-size.com which will tell you all the OEM wheel/tire options for your model/year. Actually the better play here is to keep the stock tire size for the winter and go with taller/wider summer tires. If you live where it snows you want tall/narrow tires that cut through the snow, not big wide slicks that sit on top of the snow. Simply going from a 215/65-16 to 215/55-16 will only throw off your speedo and increase your risk of a pot hole injury to the tire/rim. It won't really impact the suspension geometry but may look odd with the extra arch gap.
Old Dec 4, 2020 | 03:49 PM
Default Thank you all
Thanks for the info and resources. Actually went on up to 17s. For the winter.
Old Apr 25, 2021 | 08:17 PM
JBXC70's Avatar
Hello,
I have a 2010 XC70 with the stock 16-inch wheels and 215/65-R16 tires.
I have bought a set of the Volvo BBS Propus 7.5 x 17 wheels and I would be interested to know exactly which 17-inch tires you bought and how you like them?
The TireRack guide suggests 235/55 size tires, but I can't help thinking that a bit more sidewall would be a good idea given how bad our roads are here in LA.
Jon
Old Apr 25, 2021 | 09:54 PM
Originally Posted by JBXC70
7.5 x 17 The TireRack guide suggests 235/55 size tires,
If you are worried about potholes - then you should leave the original size wheels (16 inch) on - they can be bent with abuse also -
If you want the "cooler" look of 17, 18, 19, 20, 21, or 22 inch wheels - then be prepared to pay the price! How "cool" do you want your Volvo Station wagon to look?
Sorry I've been in the Volvo Repair business for over 40 years - and it's always been fun to surprise an unsuspecting driver - with how the "Volvo station wagon" (chipped) was able to easily pass them - but larger wheels have never been on the radar for me - I guess i'm just not into a "cool" looking Station Wagon - maybe I always wanted to blend in.
sgm
North East
Sep 24, 2014 07:46 AM
madymo3d
2001-2013 model year XC70
Jun 5, 2014 02:22 PM
sinbad
Jul 15, 2011 11:47 PM
sjonnie
Sep 25, 2008 12:38 PM
rabkay
Dec 31, 2006 12:59 PM
