2004 XC70 passenger door electrical
Old Jul 13, 2017 | 11:51 PM
awflint's Avatar
Default 2004 XC70 passenger door electrical
I just purchased a 2004 XC70 with a few electrical problems, all in the front passenger door:
* dash shows "passenger door open"
* window won't go up or down from either passenger or driver's switch
* door lock button does nothing, BUT the door lock DOES respond to being locked/unlocked from driver's door.
* electric mirror does not respond
I'm going to pick up a manual and wiring diagram, but thought I'd go ahead and ask beforehand if there's anything that sticks out as being the common denominator for all that... I just glanced at the harness as it passes from frame to door and didn't see any obvious damage.
It just seems odd that so many systems on the same door would have issues.
Old Aug 12, 2017 | 06:04 AM
Fataqui's Avatar
Hi
If I recall fuse 36 powers the right-side door module, check that first.
F!
Old Aug 12, 2017 | 12:27 PM
awflint's Avatar
I could have sworn I replied to this, lol...
Problem turned out to be non-electrical, in a sense.
The plastic pivot points for the window mechanism had broken. As a "fix", they rigged the window in the closed position, then unplugged the door control module.
A couple of bucks in new plastic bits... plugged it all back in... done.
Old Sep 6, 2017 | 10:22 PM
Voldog's Avatar
Default 2004 XC70 110k mi
I don't have the car yet but will be picking it up in 2 weeks. I drove it last week and it has a similar problem on the passenger door lock.
When I try to lock it remotely it makes this funny sound like its trying to lock. Not sure what the problem is but I plan to open it up when I get the car.
Old Sep 6, 2017 | 11:37 PM
awflint's Avatar
Does the same thing happen with the manual lock/unlock button on the driver's door?
Does the lock move ok when you physically move it up and down?
Old Sep 7, 2017 | 06:16 PM
Voldog's Avatar
I don't recall if the lock button operates manually. If so, what does it mean?
keaunym
Dec 2, 2012 05:46 PM
CDSpin
Dec 16, 2010 12:19 PM
49willard
Sep 26, 2010 02:42 PM
dvc100
Oct 1, 2009 04:58 PM
maglemose
Aug 13, 2009 11:12 PM
