2005 XC70 exhaust leak near turbo
Old Sep 8, 2017 | 01:32 PM
Mulcaheys's Avatar
Default 2005 XC70 exhaust leak near turbo
Getting a loud exhaust noise when starting up vehicle. It quiets down after a few minutes at idle speed, but gets louder when driving. Hard to see exactly where it is coming from, but sounds and feels (feel some exhaust) from upper side of turbo area. Have not taken out the heat shield to investigate further yet, but I thought perhaps someone may have a suggestion about what could cause this? Is there an exhaust gasket in that area that may need replacing? Thanks!
Old Sep 24, 2017 | 08:51 AM
tony1963's Avatar
Remove the heat shield and check for cracks in the turbo housing, or one of the three fasteners holding the catalytic converter pipes to the turbo housing.
The heat shield is held in place by four 10mm bolt heads.
Old Sep 25, 2017 | 02:26 PM
Mulcaheys's Avatar
Thanks! I did remove heat shield and it turned out to be a broken exhaust manifold gasket that slipped out of place. Replaced all gaskets and solved the problem. Thanks for your reply!
arfstrom
May 26, 2016 09:56 AM
(Austin)
Jan 10, 2013 11:40 PM
beejay
1998-2000 model year V70
Jun 29, 2012 07:53 PM
PDMS60
Jan 14, 2010 10:38 AM
SuspTech
Jan 25, 2009 09:54 AM
